Autotone on Radio
So, the stereo was replaced under warranty this morning. The "new" one automatically goes to the pop setting for the autotone when I go to the radio, and C&W on the CD. Is there anyway to change this default setting? My old one went to no setting for the autotone.
Cant remember for sure. I have had my OEM radio out since day 1.
BUT, i THINK it might default to the setting it was on at the time the channel was programed to the Preset. So in theory it could change for every preset.
BUT, i could sure be wrong?
    bellssn690
    bellssn690
  • Who's Online   4 Members, 2 Anonymous, 831 Guests (See full list)
