Trying for Navigation Upgrade for 2003 Envoy
I have a 2003 Envoy SLT with Bose and Onstar. No XM radio.
I just bought the following on Ebay last night.
GM Factory Navigation Part # 15204335
Map disk version 2.0 part # 15105609
Antenna GM Part # 15135178
While I'm waiting for this to arrive I was wondering if I will need any other parts to complete this system. I've heard about a few people having sound problems after install. Or is a trip to the dealer for a vin reprogram all I need to do. If worse comes to worse I'm sure I could resell the parts on Ebay.
Looked in cargo area behind panel on passenger side for Bose amp. Found it having a part# of 15187195. I'm not familiar with that part number at all. Does anyone know if this is lux or non-lux?
Check your glovebox for option code Y-91; that's the lux amp. There is a picture of this amp in the long Nav thread on page 2 or 3. You really need to read this thread all the way through. If you have the lux amp already it's almost a no brainer with a lux Nav.
I would like to personally all members of this board. Your help has been tremendous and informative.
My nav unit arrived yesterday. I installed it immediately using the theftlock bypass method. To my suprise the unit worked perfectly. Only thing I had to do was drive to gmc dealer a few blocks away and pay $50 to remove the theftlock.
Only thing I have to do now is remove dash and properly mount gps antenna. I just tossed it behind the radio which I know wasn't right.
Once again... Much thanks.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 1,016 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
