defrost
sonoma driver
When i drive i have the defrost on and the coldest setting and it still fogs up. There are no leaks in my system for sure. But I have noticed in my owners manual that the air compressor will not work below 40*F. I am thinking that since I was driving in 20*F weather the air compressor would not dry the air properly and just send unfiltered air to the window.
sry if this is confusing but I have to drive and wipe my window every 5 min until it gets warmed up and then it takes about 10 min for me to wipe it
If it's 20 degrees outside, why would you have it on the coldest setting?
Sonoma driver has at least one other thread on this defroster topic. I think he's still learning how to navigate through the threads and posts.
SD, I'm stumped. But I bet there are alot of other forum readers who have better ideas.
Grasping at straws, I'd check to see if the recirculate door is working. Maybe somehow you're not getting any outside air. Could be that the recirculate actuator is stuck in the recirculate position, preventing new (dry) air from entering the passenger compartment.
Also you should try to figure out why your temp never gets above 150. That's not good for the engine oil or the engine.
to gm tech if I have it on heat then it makes it so i have to wipe more often
from what i noticed is that the temp gauge goes between 100(being the lowest temp) and 220(being the middle temp)
but the thermostat works I have tested it repalced the sensor as well. Plus I know it goes over that since my mpg is about 20
Do you know for sure if the compressor is turning on? You should be able to hear and see it kicking on and off with the hood up. I would suspect it isn't working. Have the AC level checked. If it's low it might not be letting the compressor turn on.
Do you by chance have a leaky door or spilled water in the cab? If there's a lot of moisture inside it can take a loooong time to drive it out of the air.
I know it kicks on because i hear it.
As for the leaky door or lots of moisture it could be that I am big for a reg cab compact truck (6'2")and most of the time I have some one else with me about the same size so I think that may be a problem to how long it takes
    Whit.the.COB
    Whit.the.COB
  • Who's Online   1 Member, 0 Anonymous, 1,073 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
