98 Tahoe LT 350r
R.W.Trask
Hello:
The ticking - engine temp below 100 deg., oil pressure 40+, outside temp -20 to 80 degrees F. Two to three times a month, starting to idle below 100 deg. engine temp., it sounds like I have no oil - every lifter is protesting until engine temp 100 deg. F. Oil change does not help.
Main light switch elumminated when key turned to on. Horn stopped working. Air bag light stays on 20 out of 30 days. Rear view mirror does not show temp and no anti glare light.
Is my babby going to have a heart attack?
Picture and sticker
http://users.rcn.com/rwtrask/mytahoe.htm
Hello:
Picture and sticker
R.W.
Have you had the intake manifold replaced on your Tahoe? The 5.7L had a problem with the intake manifold in that after time it will start to leak. My 98 Yukon started leaking about 58000 miles. My 1996 Tahoe had to have the entire top end of the motor replaced because the coolent is very corrosive. Look at your coolent, if it is a dark brown or black color you are leaking oil into the cooling system. Then check your oil, if it is milky you are leaking coolent into your oil.
Also, just as a side note, I had to have the rear view mirror replaced on my 1998 Yukon because it did not work (i.e. temp, compass)
Hope that helps
Hello:
Picture and sticker
R.W.
Hope that helps
Reply
My 98 Tahoe 350r has 63k miles. The oil always looks great the coolent is that GM Dextrol or something - its pink. There is no sign of oil in the coolant. There are no bubbles in the radiator
    Whit.the.COB
    Whit.the.COB
  • Who's Online   1 Member, 0 Anonymous, 1,201 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
