2003 Envoy, Air load leveling
I noticed that wife's 2003 Envoy is lower on right.
As soon as I find the measuring tape and time will do some more checks will look closer at it. I know the compressor is runnig when you put ingition key in, runs for a while and then every now and then I can hear it running.
Not sure, if there is a leak or something.
I've seen some post in January on the subject with some links to the manuals, but they do not work anymore.
Does anyone know how this thing work and what I should look for to make sure it works correctly?
Ziggie
Ziggie
Each side has its own sensor. The right side may need a little "tweek" to get the vehicle level. It will have to be moved up or down to get you level. I had a similiar problem and Mr. Goodwrench at the GMC store fixed it for me.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,129 Guests (See full list)
