Lawnmower Problem
01z71
I have an older Murray 18.5 HP Briggs & Stratton riding mower. This mower has sat for a while but it has a new battery. When I try to strat it makes a click and then does nothing. After a minute or so of trying the positive battery cable starts smoking.
ANy ideas what to check or do. I think it had a new starter a few years ago. This is an old company mower that I'm just trying to see if I can get it to work.
Any ideas are appreciated. Thanks.
There's bound to be a Briggs/Straton forum around.
At a base, it sounds like maybe the starter windings may have rusted apart and is just shorted drawing very high current burning the battery.
Other possibility could be that the piston is frozen and the starter can't torque it loose, again drawing high current from the battery. Does the starter get hot?
1. Check all of your wiring for shorts/grounds. The "Click" you hear is probably the solenoid closing when you turn the key....engaging the starter, which will not work if it is shorted out or the engine is locked....But will still draw amps to where it is shorted.
2. Try and turn the flywheel on the engine by hand(wrench). If it has been sitting up it may have rusted the rings to the sleeve. If it does not turn fairly easily, thats probably it.
-Remove spark plug
-Spray oil/penetrating oil down into spark plug hole. Let it soak a while...
-Try turning it again by hand with some persuasion...
-If it breaks free, crank it with the starter and the plug out..... (WATCH the plug wire-no setting gas/oil mix from spark plug hole on fire :bs: ) to clear the cylinder.
-Reinstall plug
-See if it will crank up.
Briggs engines are pretty tough, hopefully it isn't too bad and will get turning for you; the starters are EXPENSIVE.....Hope thats not it. It would take a lot of corrosion (oxidation) for it to go bad. Usually its the flywheel gear on the starter that tears up first, not the starter. Let me know how it turns out.....Good luck. :ughdance:
OK I had a chance to work on the mower. I checked the wiring and it all seemed to be o.k.
Then, I took the plugs out (It has two one on each side) then I tried manually turned the shaft.
When I tried starting it tried to turn over a few times. I put the plugs back in (It shot the penetrating oil out) and it would try to start just not enough to get it to run.
I noticed the teeth on the starter were kind of stripped looking. I have started to take the engine apart and there is one huge bolt left to take out on top of the engine. Is it ok to take this bolt out? I want to try to spray everything down good because this mower sat outside for a while and it just sounds like something is rusted and making it hard to start.
I changed the oil in the mower just to make sure it has good oil.
Thanks for the help with this. Im enjoying having something to fix as a good weekend project.
Huge bolt on the top of the engine? That sounds like the flywheel bolt. Should not hurt anything to take it out, but it will probably be tough to get the flywheel off. I am not sure if it has a taper on the crank/flywheel or not. It is a two cylinder 18.5hp? With two cylinders across from each other sounds like an old opposed twin. What model is it? Should be on the blower housing somewhere....If it is turning over you should be a good ways towards getting it to run. All you need now is fuel and fire. If it been sitting up make sure it has good gas and the carb is not all gunked up and make sure you are getting a spark. Good luck again... :seeya:
Thanks I'll check the gas it has been sitting for a while. It's a '98 model. The place where I work has had it sitting around outside. It didn't work so they bought a new one and this one kind of got forgotten about.
I brought it to my house and put it in the garage and have been trying to mess with it in spare time. I appreciate the help and keep you updated on it.
Doesn't really sound like this may be it, but after something sits for a while, normally pouring a small amount of gas in the carb will help free it up and get it started. I do it all the time on my outboards and lawnmowers and what not.
Also, if you keep cranking on it, make sure to keep that battery charged up.
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 442 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
