Transmission Rebuild 95 Suburban 4X4 1/2 ton
Dear Group,
I will be having a transmission rebuild performed soon. Slippage getting to bother me in 1/2 and 2/3 shifts at moderate acceleration.
The tranny presently is the 4L60E with a TCI Trans-scat shift kit.
I plan to upgrade the engine at a later date with some mods for greater torque/HP in the 300 range and likely do a lift with some larger tires in the future.
Should I go with a upgrade on the torque converter at this time as well and if so what would you recommend?
Thanking You In Advance,
Glenn
unless you are going to go w/ a heavy cam w/ a big lope, I would stick to a smaller converter to keep mpg sensible. If you are just going with a little larger than stock cam, I would recommend around a 2k converter. I had a TCI Super Street Fighter 3200 rpm stall in my truck, loved it, but was a little high for my application. They aren't as expensive as some of the others, camaro guys swear by Yank converters, but I didn't have a single problem with mine.. well, I had to rim one of the bolt holes out on the flywheel slightly, but other than that, loved it. And I didn't dare check my mpg after I installed it. :D
You want to match the stall converter to your gears / cam / tires that you are going to be running. Contact the converter manufacturer of your choice, tell them your setup and they will recommend the stall you need.
good luck!
    ar0517
    ar0517
  • Who's Online   3 Members, 0 Anonymous, 566 Guests (See full list)
