1998 GMC1500 door mirror removal
If I remove the small triangular panel inside the door (near front edge, top of door panel), can I access the hardware to remove the door mirrors on this truck?  I want to paint the mirrors, they are in terrible shape.  How do I remove the movable portion of the mirror from the base? (Torx bolts from the bottom?)
Ya pull the little plastic piece off and there should be a wiring harness and three bolts to remove the mirror's completely.  As for the mirror itself, you should be able to remove it through the edge that's hooked onto the truck.
    CaptainDad
    CaptainDad
  • Who's Online   1 Member, 0 Anonymous, 465 Guests (See full list)
