hypertech saved my baby!
ok, it didnt really save anything baby but im extremly happy with my power programmer III. i bought a used one off of ebay for $199 and it came today and i installed. it did do noticeable power gains, but more importantly to me it seemed to have cured all my problems! i had the rough acceleration in 1st gear that i was positive had to be tranny problems. it felt as if i was accelerating on a cobble stone road, no noise, no signs of the engine having any problems, but i guess i was wrong, after i installed the hypertech it doesnt do it anymore!
and also, i had a grinding noise from under my hood that only happend with the a/c on, so it HAD to be the a/c compressor. i tried oiling the sucker down, and nothing. refrigerant oil, nothing. and now with the hypertech it doesnt do it anymore? it has to be my imagination.
d**n, i should be a spokesperson for hypertech
and i can finally perform in bed again! :cheers:
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 1,065 Guests (See full list)
