Double online discounts - save up to $500.00!!!
Yes, we are at it again! This sale has been popular in the past so we have brought it back again. Our online ordering discounts are doubled for orders that are placed on our website through Sunday evening (7/17). This covers all regular priced products. Superchargers, nitrous, rearends, headers, exhaust, inductions, suspension products, torque converters, intake manifolds. rollcages, wheels, tires, lighting, short blocks, stroker kits, clutches, torque converters ect, ect, ect....
The chart below shows what your discount will be for regular priced orders that are placed online -
Order Amount ..................Discount
$150.00 - $249.99..................$20.00
$250.00 - $499.99..................$30.00
$500.00 - $999.99..................$50.00
$1000.00 - $1499.99...............$100.00
$1500.00 - $3999.99...............$200.00
$4000 + ................................$500.00
NOTE: Discounts can not be combined. Online ordering discounts are only available for our regular priced items and do not apply to GP, sale, price match or package prices. Discount based on dollar amount of sale in one day.
Be sure to let us know where you saw this ad so we know where our advertising dollars are working!
Have a good day!
ORDER LINE - 1-877-4-TBYRNE (1-508-636-0770 in MA)
E-MAIL - [email protected]
NEW WEEKLY SPECIALS CAN BE SEEN ON - OUR WEBSITE
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 393 Guests (See full list)
    • 2013 5.3 still to this day calls for the PF48 filter.  Which as a 15psi bypass pressure.     There is a TSB, 17-NA-157 that talks about the PF-63 and PF-64 filters which have a higher bypass rating of 22psi.    TSB HERE - temp.xml   "Beginning in 2012, the oil pumps began to regulate main gallery feedback instead of pump out pressure. This means that the oil pump now does not begin to regulate until pressure is built up to the main gallery. This change reduces the amount of time it takes to provide oil to the engine bearing and lifters during extreme cold start conditions.  Main gallery feedback oil pump control systems are present on the following engine families which use Spin-on oil filters: Small Gas Engine (SGE), Large Gas Engine (LGE), High Feature (HFV6) Gen2 and Small Block Gen5 gasoline engines. These engines with the main gallery feedback oil pump control systems are factory built with an ACDelco® oil filters"   It also calls out what engines use those filters.  The gen 4 small blocks were not on that list (LMG, LC9, L9H, L92, L94, L20, L96).  Gen 5 small blocks use the higher pressure filter.
    • To me it honestly makes zero difference what filter you run. It's not a race engine, just a truck engine that's mostly bumming highways and it just needs a filter that filters oil.   The filter used to be a 7060 and the long version was a 7045. Now it's the newer updated filter that the K2XX trucks and newer run, the 100255 I believe if we are using napa numbers. Any of those filters is going to do the job.   I wouldn't overthink it, to me it makes no difference because those first filter numbers worked for 18+ years before the spec suddenly changed.
