True DIY exhaust system
I have a 2002 Silverado 1500HD that I recently tore apart the top end and reassembled trying to find a cure for my piston slap, no luck but I managed to install a few power adding pieces to the mix in the meantime. I have been looking for a new cat-back exhaust system and I have learned that Flowmaster & Magna flow requires welding for installation. I don't have a welder on hand and I flat refuse to have anyone else touch my truck. Does anyone know about an exhaust system for this truck that is truly a do it yourself kit that simply friggin' bolts on? :chevy:
Corsa is bolt on, thats junk? If you say so. Just look around. Check silveradoss.com and see what is used by the majority, i found a lot use corsa. I bought one and i loved it.
Thanks everyone for your input. I looked into Corsa, I even called them. They don't make a kit for the 1500HD 6.0L but they make a kit for every other 6.0L truck that GM makes. I ended us with a S.S. Gibson kit. It "Bolted" on with ease took 10 minutes to do. I would go with a welded kit but WTF, then when it breaks again, which will happen. Thanks for the tip on the Gibson kit chevydeerhunter! :cheers:
    ar0517
    ar0517
  • Who's Online   2 Members, 0 Anonymous, 648 Guests (See full list)
