Emergency Tire Help Now!!!!
:chevy: Need some good quick info. Tire guy is having trouble getting me the 285/75s I wanted for th rado 02 z71.
He's got a set of 305/70's
WILL THESE FIT???? How much difference are we talking about in size???
Anything else I should worry about beside rubbing. This truck is stock with stock rims and no lift. Torrsion bars are cranked up a little and It will get an alingment at the same time the tires are installed.
What do you all think?????
I have read that these will fit but I have no experience with them.
Based on a tire size calc they are virtually identical tire heights just the 305's are 2 centimeters wider or about 1 inch wider. I would ask the tire place if he could test fit them. I would guess they wouldn't be a problem with that small of a difference. May have slight rubbing at full lock.
I'm probably not much help but at least I could pass on the difference in size to put it into perspective.
i saw a z71 with these size tires once. im pretty sure it had stock rims and i dont think it was lifted, maybe tbars cranked. but it looked pretty sweet. i also dont remember if the bumper was trimmed.
please dont rely on me though! im very unreliable!
You should be ok on height, but the width could be a problem. Someone else on the board recently put 295/70/17s on a stock z71 and they are fine.
295/70/17s
Those tires are 33.3" x 11.6"
305/70/16s are 32.8" x 12"
So if that is 1.6" wider than the stock 265/75/16s
    hotfish
    hotfish
  • Who's Online   6 Members, 0 Anonymous, 839 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
