ADDING MEMORY SEAT OPTION
Can you add the memory seat function to an 04 silvy I have the power driver seat . Would you have to add the heated function also. What are the part# you would need for this coversion if it would work. Thanks :crackup:
I have an '00 and would like to have seat memory as well.
If anyone has more information, I'd love to learn more about it.
In order to get this to work you will need the memory seat module that is located under the driver's seat that controls memory, power seat function and heat to both seats which I believes runs $300. I am also not sure if you will have the correct wiring harness under your seat to make this work. You will probably also need your BCM reprogrammed to except the memory seat module.
The seat motors are also different, the memory ones have indexes that provide feedback to the memory module. You will also need the switches on the door panel, and the whole harness setup. the correct wiring is not going to be there.
I checked it all out when I changed my seats to the leather power heated seats.
    Patrick Fergy
    Patrick Fergy
  • Who's Online   3 Members, 0 Anonymous, 1,014 Guests (See full list)
