Getting used to the new XL
I now have almost 2K miles on the Yukon XL, and I'm really starting to get a feel for this vehicle. It has lots of power, but I'd like more. Highway cruising is effortless and very smooth. I've done very limited off-road for now, but that will come.
A few observations...
The motor is a monster, and has massive torque. It makes you smile, big time, every time.
The fuel mileage is slowly inching up, from about 11 to a new high of 12.6 mpg, but that isn't why I got the truck. It is hard to keep your foot out of it. The fuel cutoff starts to happen at 5K rpm.
The factory has the truck so quiet, you really can't even tell it is a big block, and that needs to change.
Fit and finish are great.
It has a dual in/dual out muffler, all pipes 3". The out pipes go into a 3" Y to a single 3" out behind the passenger rear wheel. Magnaflow has what looks like a decent replacement that will probably need to go on soon (Part #12599). Has anybody used this particular muffler? I know Magnaflow is a very popular muffler on this board.
Just thought you would like some first impressions. This thing is sweet...
Jim
    bellssn690
    bellssn690
  • Who's Online   4 Members, 2 Anonymous, 831 Guests (See full list)
