lock ring on top of fuel pump
I can not get theat metal lock ring on the top of the fuel pump to spin off
how in the hell do you guys do it?
Everything was going so smoothly
matter of fact i had the tank completely dropped out of the truck in about 15 minutes
but then this
whats the secret?
If I remember correctly, stick a small screwdriver under one end and carefully pry up and out of the groove. Use a second tip to work around the edges while you are holding the first end up and it should pop out.
That method should work. It's called a snap ring. Mechanics use snap ring pliers for them =).
I do not remember it being a snap ring that would use those pliers when I did my fuel pump, but maybe.
I didnt describe it very well cause at the time I was pissed off about it
Its a metal ring about 10 inches in diameter that locks down on the gas tank by some metal prongs when you sping it counter clockwise itll come offr and clocwise to tighten it
I dump an entire can of pb blaster on it and let it sit while I ate dinner and it finnally came off
everything was going soooo smoothly till that
for guys doing a fuel pump
there is no way taking the bed off could be easier on these trucks
it took a solid 15 minutes to get the tank out
I used a floor jack and a piece of plywood 2 foot by 3 foot and just lowered it down
spen about an hour getting that d**n lockring off and about 45 minutes putting the tank back in
ive never done a fuel pump before but i am fairly mechanical and i was working by myself
my tank had about 1/4- 1/8 a tank of gas
the guages in these things arent worth a s**t
the light came on to tell me I had low fuel and i parked it right aroun that time to do the pump
hahah that tank weighed like 75 lbs still
if i had a gas tank or 5 gallon tank to put cas in it would have bee a hell of alot easier to put that tank back in
Its plastic so the tank itsself isnt heavy
I just used a pair of snap ring pliers when I replaced my fuel pump last week. It turned pretty easily once I used the snap ring pliers.
good luck,
Michael
but then this
whats the secret?
    ballencd
    ballencd
  • Who's Online   2 Members, 0 Anonymous, 473 Guests (See full list)
