I have some ?'s
I have an 89 GMC Sierra and am wondering if you can take out one of the rear leafsprings so the back end will sit lower? Also my truck has enough oil, but the oil pressure gauge shows no pressure when the truck is idleling. Anyone have answers?
I don't know about the leaf springs, but I had a '91 Chevy that did the same thing once with the oil pressure.  I changed out the sending unit and it fixed it.  Mine had the 350 in it and I had to remove the distributor just to change the sending unit out.  I don't have the truck anymore, but if you need anymore help, just ask.
Hope this helps.
Oh yeah, welcome to the site.
(Edited by MountaineerTom 99Z71 at 8:47 pm on Mar. 17, 2001)
I'd be willing to bet that Tom is dead on about the gauge problem and I've also heard that you can take one leaf off of each side and your truck will still function properly.
Welcome to the site!
Thanks, I have been looking for a good GM truck message board. I will try putting in a new sending unit and see if it fixes the oil pressure prob. Which leaf should I take out if I decide to?
The longest one, oh wait, that's the one with the bolt holes. Ah,,, try the shortest one.
Does the Teamgreen name have anything to do with Kawaski dirt bikes?
TeamGreen,
The only reason I needed to remove the distributor on mine was because I couldn't get a wrench on the sending unit and get enough movement on it to remove it.  Make sure you make a reference mark or something so you don't get anything out of whack.  You probably already knew that though.
Probably is the sending unit, and it's a pretty cheap fix, too.  The other possibility is that your main bearings are worn and you're losing pressure at idle, however, that's pretty extreme wear.  Even if they were worn you should be showing some pressure at idle, even if it's a bit too low.
Definitely start with the sending unit.
Jeff
I just started to notice that when my truck isn't at running temp yet it still has full oil pressure. Once it warms up the oil pressure goes all the way down when I stop.
Team green,your sending unit isnr behind the distributor,the 89's have it above the oil filter mount,it is easier to get to than on the 91's.I have both an 89 and a 91,GMC,s,both have had the oil sender go bad.I hope I am wrong-but it sounds to me like your oil sender is working fine,and your engine is worn out,the low oil pressure at hot idle is common when the engine gets loose.When my senders went bad,they pinned the guage as soon as you turned the key on,when it wasnt even running.replace it anyway,or put  manual guage on it,if you have less than 12psi at hot idle,its rebuild time.I would change the oil,and filter first,use at least 10w30 oil,and dont use 5w30,it is to thin for your old engine.You didnt mention how many miles are on your truck or if if the oil has been changed regularly.
If it is excessive wear that's causing your problem you could try running 20W-50 motor oil for awhile, but it is just a band-aid temporary repair until you get the engine rebuilt.
My truck has 104,000 miles. Do you think the engine could be worn out at this many miles. I just changed the oil and its doing the same thing. Maybe the dealer I bought it from lied to me about the miles. I don't know?
New sending unit , then try 50w raceing oil when it gets hot out it will come up then. my 63 has 60psi at idle with HV  HP  pump. Normal chev. pressure is  low for some reason ,but it is best oiling system out there.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
