Air Conditioner Engine misses
dickhoff
97 GMC 2500 5.7 liter full size pickup truck
Engine misses at low speed when A/C is turned on. Seems OK at hight speeds.
Any suggestions?
:nopity: Ed
Any suggestions?
Move to Alaska? :nopity:
Define "low speed" and "high speed". Does it do it at idle speed? Are you sure it's not the normal A/C cycling on and off?
GM-Tech,
At idle speed with the A/C turned on the engine misses. Not the A/C turning on and off.
Above idle speed engines run OK. Highway driving i can not detect a miss.
If the A/C isn't turn on the engine run OK at all speeds. There is no check engine light. Hope this helps.
:nopity: Ed
GM-Tech
I test drove the truck today. It's an Automatic. Transmission in Park or neutral
with A/C on engine sound Ok. Driving the truck with transmission in Drive and A/C on,
engine misses at stop lights, engine idling. As soon as it come off idle missing stops.
Hopefully i gave u all the information this time. Should have paid attention first time.
:nopity: Ed
    blueskytruc
    blueskytruc
  • Who's Online   0 Members, 0 Anonymous, 599 Guests (See full list)
