Ran some SeaFoam
Not sure if it even made a difference on a truck with only 10,300 miles.
It took about 30 minutes to do for each car. I ran 1/4 can real easy through a vac. line, then revved to about 1500 and sucked the rest of the can down, and towards the end I let it stall out. -- Sit for 20 minutes while I did the car.
It smoked pretty good for about 2 miles then stopped. It was pretty funny clearing out a major highway..lol
The car howerver...dang. 98 Grand Am 3.1 88,550 and it had never been done. That sucker smoked like the house was on fire and it was like that for about 30 minutes of driving. I may do a second application for the car.
Next is the work truck--I'm going to suck 3 cans down that bad boy----it idles 13+hrs a day so I'm sure its real nice and crusty.
I sucked it through the brake booster vac. line.
I got a small adaptor to fit in the hose so it wouldnt suck it too fast and hydrolock the engine. It worked perfect, i regulated it some then after 3/4 of the can I took the other 1/4 and went real strong until it stalled.
Smoked like a bear...
Does it work good?
You can buy the same stuff at your local GM dealer. I believe they call it "Top End Cleaner".
It smooths out your idle and cleans out the deposits on the top of your pistons etc... In most cases it helps clear up any "piston slap" or engine knock too...
I'd recommend doing the procedure just before you change the engine oil.
Does it work good?
ive been thinking about running some sea foam i have a 2000 chevy 2500 with the 5.7 do u recomend this and how do u do it i saw some ant auto zone. oh yea have about 93k on it
    hotfish
    hotfish
  • Who's Online   6 Members, 0 Anonymous, 839 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
