New Headers
I am looking for interest in a group buy for new Tri Y headers from Clear Image Automotive for 99+ SUV and Trucks.
Details
Made of 14 gauge mild steel (.083 wall thickness), the header flanges are 3/8" thick CNC laser cut and machined flat for a leak-free seal. The final collectors utilize a ball-socket flange for easy hook-up to the custom, bolt-in Y-pipe. The headers are available with either 1 5/8" primary tubes for normally aspirated applications or 1 3/4" primary tubes for forced induction or stroked motors.
NO WELDING IS REQUIRED FOR INSTALLATION
CHROMEX polished aluminum ceramic and satin ceramic coatings will also be available.
The Y-pipe is 2 1/2" Mandrel bent aluminized tubing into a single 3" collector which uses the GM ball flange for a true OEM fit to the cat-back exhaust system. The Y-pipe can be ordered for off-road applications or with dual 590 cfm high-flow catalytic converters.
The converters are made of 100% 304 stainless steel, including the spiral wound substrate.
Headers, Y pipes and Cats are available seperately.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,218 Guests (See full list)
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
