FS: new Magnaflow Y-Pipe
SierraCrew
Brand new, never installed 3" inlet/dual 2.5" outlet magnaflow Y-pipe. Was going to use it with my single in/out corsa muffler to run dual pipes, but the muffler is so d**n big, I am not going to have room to do it. So I am now selling this thing. Asking 45 shipped for it.
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 685 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
