Alternator size in a 2500HD??
How can I tell my alternator ( amps) size in a 2005 2500HD 6.0 ??
Look in your glovebox at the RPO label and read the ones that start with a "K"
Here are your choices and amps..
K68-105 amp
KG8-130 amp
KG3-145 amp
KW1-160 amp
As builderpaul said 105 is standard and 145 should be the one that comes with the snow-plow prep pkg. on the HD's.
160 amp comes on the 1/2 tons with the snow-plow prep pkg.
(130 used to come on the HD's with the snow-plow prep and 145 on the 1/2 tons but GM upped the amps a couple years ago.)
    bellssn690
    bellssn690
  • Who's Online   4 Members, 2 Anonymous, 831 Guests (See full list)
