Hummer Wheels
Truckman031
I appreciate it. I didn't even think to google it. I was wondering, because a local Hummer dealer is selling stock h2 wheels and tires(BFG AT 315/70s) for $600. A friend of mine was going to buy them for his 00 Z71, then lift it to run the tires. Thanks again!
    • *Your
