Electrical Conector
divejoe
In the process of installing the starter in my 2000 Silverado 1500 the wires of a connector just above the starter came off (connector stayed in). I have no idea on which order do they go. They are green, blue and yellow with a three way connector.
Could you please advice on which order do they go? For example green center, yellow right corner (looking from the top), etc.
Also, which is the best way to install the starter, I tried with the cables connected and is a pain in the arse; however, it goes in easily without the cables but there is no room for a wrench.
Thanks!
I'm unclear what it is you're talking about. What do the wires go to?
Now that I think about it, that sounds like the crankshaft sensor wires. If that's right, blue/white goes into terminal A, Yellow/black terminal B and Lt green Terminal C.
You're the man! That's the one. Once again you saved the day!
Thanks!
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,155 Guests (See full list)
