4x4 vibration
firerage101
I have a floor mounted shifter for my 4x4. The other day while using 4 wheel drive this horrible vibrating noise came from the floor shifter im lost :D is this normal for it to have odd noises
I would have to say that horrible noises are probably not normal.  :cheers:
:D Well it sounded a bit like the shifter vibrating and hitting the panel on the floor, but it would come and go. Either way it's horrible when it's around. maybe i'll go have it looked at next time i drive 3 hours into the city
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,137 Guests (See full list)
