DRL's
Need some quick help. I have one drl burned out and need to replace. I've looked at the lights and found the "L" shaped rods to remove the main head lights and done a moderate search on the subject with no luck. How do I get to the bulbs to change them out?
1st - pull the rod to remove the main headlight assembly. you can lay the
main assembly over the front of the truck with the wires, wont hurt it.
2nd - you need to look down into the space below where you pulled out
the main headlight assembly, and you will see the drl assembly.
there is a little PUSH KNOB attached to the side of the drl assembly.
push in and the assembly comes out the front of the truck. once you
do it once, it is so SIMPLE. after you change bulbs, just push the drl
assembly back into its position, and make sure the push latch is back
in place.
replace drl's with sylvania double life AMBER BULBS, they are awesome!!!!
you can get them at any good auto parts store.
hope this helps a little :sigh:
    BigJake
    BigJake
  • Who's Online   4 Members, 0 Anonymous, 591 Guests (See full list)
