Radio Removal Questions
windfall
We have a 2004 Yukon I want to install a xm satellite system. I want to see if the radio/cassette/cd player I have will accomadate this install. I have taken the dash panel off and removed the three (3) screws that I believed holds the unit in place, but the unit still will not pull out? Is there a hidden screw or something that I cannot see :) any help will be appriciated.
Thanks,
Mark
Thanks,
Mark
i thought there are only 3 screws ... 2 on the left and 1 on the right...
and back of the radio there is a white small knob that holds with the dash... i think...
try to shake and pull ... if that doesnt help ... dont know sorry about that...
The "pin" at the lower back of the radio is nylon, with ribs, and it press-fits into a rectangular hole in the dash as you tighten the screws in front. After you have the screws on the front removed, see if you can shift the radio's front to the right and left just a bit, just enough to confirm that the press-fit pin at the back of the radio is the pivot point.
Once you've confirmed that the nylon pin is what's holding it, just give it a little more pull outward and it should come out. You'll be dragging the pin through the hole, and possibly shaving off 1/32" of the ribs on the nylon pin as you pull.
Thanks,
Mark
What do you mean a small white knob....? What do I do with this knob? do I have to unscrew it or just by pulling and shaking will it release.
Thanks for the reply.
Mark
Thanks, I'll try it in the morning.
Thanks again,
Mark
Yeah, the pin in the back that locates the rear of the radio can give you a little bit of a tough time, but basically, wiggle and yank. You can't get behind the radio to do anything with that locator pin so you just have to use a bit of muscle sometimes. There are no other screws besides the three in front.
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 504 Guests (See full list)
