Heater Core Replacement
vittro
hi my heater core went out yesturday and i got a new one but its really hard to get to i have my dash pulled out and all the bolt off but the heating case wont come out it looks like i have to disconnect the AC lines (2) i really dont want to do that. is there any other way to get the core out. i looked up the net and some say to just unscrew the bottom casing. is this true. plz help i need my truck and a heater. :D
Sure you have to disconnect the a/c lines to pull the case. The evaporator is within the case and it has to come out with the case.
Just disconnect it and get it over with. Trying to shortcut these things almost always causes more trouble than it's worth and you end up taking more time to do the job than if you did it the right way.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,137 Guests (See full list)
