a couple of jokes
PELICAN
A group of Indiana friends went deer hunting and paired off in twos
For the day. That night, one of the hunters returned alone,
staggering
Under the weight of an eight-point buck.
"Where's Henry?" the others asked.
"Henry had a stroke of some kind. He's a couple of miles back up
The trail," the successful hunter replied.
"You left Henry laying out there and carried the deer back?" they
Inquired.
"A tough call," nodded the hunter. "But I figured no one is going
To steal Henry!"
The young man from Indiana came running into the store and said to
His buddy, "Bubba, somebody just stole your pickup truck from the
Parking lot!"
Bubba replied, "Did you see who it was?
"The young man answered, "I couldn't tell, but I got the license
Number."
staggering
  Inquired.
  To steal Henry!"
  Parking lot!"
  Number."
im originally from indiana :D
