FIPK....Increase in MPG and Power???
Just curious if any one has experienced a significant increase in their MPG with the K&N FIPK.  I'm thinking of getting one for my Tahoe(5.3L 4x4), and was wondering what kind of results everyone's been getting......
I would think that at best you might see 1/2 mpg increase.  I noticed a slight improvement with my '00 Silverado 5.3L with the FIPK installed.  It takes the computer a little while to fine tune itself once the unit is installed.
Unfortunately you may see a short term drop in mpg due to the enjoyment of the improved response. :)
Your "puter" should reset if you follow the remove the battery connection step. :thumbs:
I would not personally recommend an FIPK anyway and would steer you toward the UPD kit.  The FIPK will still pull in hot air from the engine area, whereas the UPD uses the stock lower airbox with a modified upper and air tube assembly with a K&N filter.  The FIPK has the possibility to get real dirty and possibly pull in crud as it is an open element filter inside the engine area!  They have a group purchase right now for $209 on your doorstep for colors or $189 for black delivered.  Just type Group Purchase in the memo/comment section on the order form.  Price is good until April 19!  I got mine a few weeks ago and performs very well.  Take a look at: www.ultimatepd.com
Dave
I didn't notice any increase in MPG.  I did notice an opening up of the engine!   I have a Tahoe with 5.3 and would recommend this.   See my pics at Http://www.picturetrail.com/greenejr  I have it in combination with a single Flow 70 with dual outlets.  You will have a increase in intake noise!  It sounds like a four barrel carb and you will hear it!   This is my second FIPK,  I had one on a Jeep Grand Cherokee before.
Let's just say that I've seen a 3 mpg increase in mileage since I took the damn FIPK off.  While it may have some advantages at wide open throttle, in "real-world" driving, I saw a loss of mpg and loss of mid-range throttle response.
  • 4 months later...
I am considering a UPD kit for my '01 GMC 2500 XL w/6.0 liter engine. When the vehicle was new I installed 265 Michelins and got rid of the 245 F'stones that came on it. The dealer reprogrammed for the 265's at that time. My question is this: If I disconnect the battery  during installation of the UPD kit and allow the computer to reset itself does it reset to the 245's or retain the 265 setting? I don't have a HPP (yet).
<snip>
Dave: How did this GP get started? Anyone know if another is in the works?
Sounds like a nice piece.
Randy :cheers:
I have a FIPK and a Gibson cat back exhaust on my 01 4.8. I would have this combination again in a second. Much better power all through the band then stock. I just wish I had access to a dyno. I am serious this is a perfect combo.
Hey TahoeJeff, you have the same setup as i want to get.  FIPK and 70 series flows.  HOW DO THEY SOUND?  DO YOU LIKE IT? CAN YOU TELL ANY DIFFERENCE IN PERFORAMCE, or THROTTLE RESPONSE?!  Thanks
Ben
I have kept very detailed records on mileage.
New to 1385 miles with no mods:  15.8643 mpg
Installed FIPK at 1385 miles
1385 miles to 3237 miles:  15.8636 mpg
<Your results may vary>. First of all, when I went to the  285's, I lost over a mile per gallon and low end seemed to suffer. I got the HPPIII and did the 93 octane tuning and got back to 15.5 from 14.7 mpg. My 0-60 best time was 8.43 afterwards which was noticeabley quicker than before. THEN I put on the  FIPK. I fired it up and it promptly died when I put it in gear. It ran terribly for a few minutes. As the computer learned the new induction, the engine came alive. 0-60 of 7.68 and 16.5 mpg are now the rule after a couple hundred miles. I can baby it over 17 mpg if I have to. FIPK/HPPIII together are a winner for me.
I can't answer if the FIPK alone will increase MPG but with true dual exhaust and FIPK done at the same time I saw a 2 to 3 increase in MPG.
Of course with any mod that changes the pitch/tone of the engine/exhaust, you really have to avoid the temptation of getting on it.  Probably the best answer to increase MPG is a light foot.
Well, I have "installed" a HPP3 to go with my FIPK.  We will see how it effects my mileage.
BTW, I chose the Power tuning for 87 octane.
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 501 Guests (See full list)
