Denali Headlights
Hey is it possible for me to put the projectors from a Denali in my 2006 sierra???
Is it Plug and Play
Is it Plug and Play
It should be...they are plug n play with the 02-05s...You just turn the two head light pins and pull them up, take out the bulbs and swap in the denali lights or aftermarket dual Halo bulbs...that's it though...the markers are all different sizes due to the denali front end being all different outside of the light size. Oh and the Denali lights are both 9005 Hight and Low beams.
  • 1 month later...
  • 1 year later...
What about the 2001 (I'm not even sure if there was a Sierra Denali in 01? Never seen one)?
Is it Plug and Play
They should be a direct fit and PnP.
Look for a '01 Sierra C3. That was the first Sierra Denali I believe.
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 1,130 Guests (See full list)
