what else ?
I purchased a 1997Suburban LT, about three weeks ago. It had front end problems so got a good deal on it. The front end seemed to go to the left while breaking, and had a little wobble. So I changed out the two front rotors, and the ball joints. the left balljoint was the worst. New Ideler and pitmen arm. Now doing this it helped a lot. But it still goes to the left while breaking. So I think its the left caliper sticking, and replaced it with a new one. But still goes to the left :jester: .
Now could it be that the right caliper is not working well, that the piston in caliper is not working? If anyone could help, I'll preciate it much.
Could be that your right frt calpier is ceased up, or you may even have some sort of restriction in the flexible rubber brake line itself.
MAKE SURE that your caliper slides AND both front spindles are perfectly clean and shiny. ANY type of rust on either the caliper or the spindle can cause the caliper to bind, which would create a "pull" when braking. Don't forget to use some caliper lube on the spindle when reassembling.
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 445 Guests (See full list)
