Voiding the warranty?????
What does and does not void a warranty on a new gm truck? I'm told we can turn the motor up somehow by lowering some torque thingy? Will this void it? How about a lift? Or bigger tires? Thanks!
well alot of stuff voids the GM warranty, I mean a lot. BUT I believe the "torque thingy" you are referring to is Torque managment and yes lowering the torque managment will significantly "wake up" the Motor. although the only way to remove/lower the torque managment is a tune, and that does void your warrantly IF THE DEALERSHIP FINDS OUT. Now i refuse to start a "Dealer detectability" or Tech 2 war here but from my experience a good PCM tune is indetectable by the dealer. Not a Hypertech or any of those handhelds.
Onto the lift question, a lift will not in my understanding void your warranty, but it all depends on how the lift is attached to the trucks, if the lift is one of the cut and weld lifts than it might cause a problem, if it is a bolt on than it shouldn't cause a problem.
Tires should never void your warranty unless you stick 45's on a half ton and snap axles and rearends but that is a whole other issue. so no
I hope i have been of help
They will argue that larger tires void parts of your warranty. Had them argue it on my tranny, diff, power steering, and everything else that went wrong with my truck. I only had 285/75R16 on it too.
Alot of this is avoided with a good dealer. When you buy the truck, go meet with the service manager and question him about warranty. Aftermarket stuff only voids warranty if they can prove that the part caused the problem. I have bought 3 new GM trucks so far in my life(I'm 27) and none of them have had a problem that didn't end up being a Technical Service Bulletin or recall.
This info might also be helpful -
Legally, a vehicle manufacturer cannot void the warranty on a vehicle due to an aftermarket part unless they can prove that the aftermarket part caused or contributed to the failure in the vehicle (per the Magnuson Moss Warranty Act (15 U.S.C. 2302©) . For best results, consider working with performance-oriented dealerships with a proven history of working with customers. If your vehicle manufacturer fails to honor emission/warranty claims, contact EPA at (202) 260-2080 or www.epa.gov. If federal warranty protection is denied, contact the FTC at (202) 326-3128 or www.ftc.gov. For additional information, check out the following links:
Consumers Bill of Rights - http://www.enjoythedrive.com/content/?id=8123
What You Can Do If Your Warranty Is Denied - http://www.enjoythedrive.com/content/?ID=8124
Federal Warranty Laws - http://www.enjoythedrive.com/content/?id=8128
Vehicle Manufacturer Warranty Contact Phone Numbers http://www.enjoythedrive.com/content/?id=8129
I've sound that some dealers don't mind aftermarket parts while others try to give you a hard time about the small things. The info above tells it like it is through.
Tom
    appletrav
    appletrav
  • Who's Online   1 Member, 0 Anonymous, 280 Guests (See full list)
