HELP! 1999 silverado 5.3 p0300
1999 chevy silverado z71
5.3 motor
P0300 CODES MISFIRE
MISFIRE ON MOST CYLINDERS
MISFIRE ON #3 CYLINDER VERY BAD
CHANGED PLUGS, WIRES, FUEL FILTER
CHECKED EGR VALVE, NOT BAD
CHECKED FUEL PRESSURE LITTLE LOW
AT SOMETIMES 48LBS BUT THEN HOLDS AROUND 55 AT IDLE WHICH IS FINE
THE PROBLEM!!!
MY TRUCK IS HARD TO START, HAVE TO GIVE IT A LITTLE GAS
WILL NOT STAY STARTED WITHOUT BEING ON THE GAS OR IF IT DOES
IDLES AT 300 OR 500 RPMS
VERY ROUGH IDLE! SHAKING A LOT
ABOUT TO CHECK THE CONVERTERS
ALSO WOULD THE CRANK SENSOR BE A PROBLEM. JUST ANY HELP PLEASE
DOING DISASTER RELIEF 700 MILES FROM HOME, NO PAY AND NO WAY HOME
PLEASE ANYTHING WOULD BE GREATLY APPRECIATED
5.3 motor
P0300 CODES MISFIRE
THE PROBLEM!!!
Don't think it's the converters, even if clogged, they will usually idle ok but lose performance as the revs go up. If you've determined it's not plugs, wire or coils then I'd lean toward a vacuum leak or a clogged injector, probably #3.
Cleaning the throttle body may help. Clean the mafs too.
Does it run alright once you get moving?
Could you have gotten a bad tank of gas?
5.3 motor
P0300 CODES MISFIRE
THE PROBLEM!!!
WHEN I GET MOVING IT STILL DOESNT HAVE THE POWER.
PUT INJECTOR CLEANER IN IT AND NEW TANK OF FUEL SINCE THEN
TRUCK HAS AROUND 160K MILES
IF THE CRANK SENSOR WERE BAD WOULDN'T IT JUST NOT RUN AT ALL??
ALSO ON THE SCANNER IT READ #3 CYL WAS REALLY MISFIRING BUT ALL CYLINDERS WERE ACTING UP.
JUST A LITTLE MORE INFO
ALSO NOT ABLE TO LEAVE THE GUAGE ON OVERNITE
CONVERTERS NOT POSSIBLE??
Clean the idle air control valve, perhaps.
WHICH VACUUM LEAK WOULD I CHECK NEXT TO CYLINDER #3? OR EVEN CHECK THE CLOGGED INJECTOR?
ALSO CHECK MY OTHER POST IN GM TECH AREA BECAUSE THERE IS MORE INFO. IT HAS A P0400 CODE AS WELL.
I know its a long shot, but make sure you wires on the PCM are tight, especially if you have ever had it out. I had a VERY similar problem on my 97 and my dad had a very similar one on his 99, I spent 400 bucks before I found hte problem. Might wanna clean out the EGR too.
Hmmm, well the P0400 is a EGR code. Usually a clogged or stuck open EGR will run OK at normal driving speeds though.
You may very well have a few problems.
As for the injector, the easiest way to check is to swap the #3 injector to another cylinder and see if the problem follows it!
    CaptainDad
    CaptainDad
  • Who's Online   3 Members, 0 Anonymous, 487 Guests (See full list)
