Code P1345
:crazy: I have 1996 GMC 2500 4wd 5.7Vortec it turnsover and turnsover but dont start i got a code P1345 i replaced the cam sensor and crank sensor it will still not start can anyone tell me how to get this truck going please help me out
Could be alot of things.
Here some things to check for that code straight from the service manual:
Check the following items:
A loose or missing distributor hold down bolt
A loose CMP sensor causing a variance in the sensor signal
Incorrectly installed distributor - 1 tooth off in either advanced or retard positions
A loose distributor rotor on the distributor shaft
Excessive free play in the timing chain and gear assembly
    Patrick Fergy
    Patrick Fergy
  • Who's Online   2 Members, 0 Anonymous, 731 Guests (See full list)
