Accessories for 2005 jimmy
I have just purchased a 05 Jimmy . I am looking to deck it out a bit but new guards and step bars cost a lot . Also there is nothing out for 2005 year . Would anything from 2000 to 2004 fit mine without alot of modification . Any advise would be appreciated.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 2 Anonymous, 831 Guests (See full list)
