Check Engine soon
Seems like my check engine light comes on about once a month; in the last 6 months I've replaced one injector, had several cleaned and replaced two O2 sensors. I am using mid-grade gas. What can I do to keep the injectors in good working order? :chevy:
Dirty injectors are a fairly common problem, usually caused by rust and sediment in the fuel lines. About the only way to really cure this problem is to remove all the injectors and have them all cleaned and preferably flow matched. Then, while the injectors are out, a complete flushing of the fuel lines and fuel logs from the filter forward Flush from both sides. Remove the filter and run the pump for a few seconds with a hose on the line into a plastic jug. Carefull, almost 60 psi here. Replace the filter with a new one and reassemble everything.
An gas higher then regular is a waste of money since the additives is in all grades. Using Premum only slows down the burn rate and causes carbon to build up in the combustion chamber. Use top tier fuel.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 1 Anonymous, 524 Guests (See full list)
