Pro Comp Shocks
Well,
I just got back from 4Wheel Parts in Fresno and they did an outstanding job installing my new Eaton Posi. I was asked in another forum what I thought about the Pro Comp MX-6 shocks. Overall, a GREAT shock. Definatley firms up the ride, so if you are a lover of the stock ride quality, steer clear of these. I picked up my trailer from the dealer and the sag was definiftely reduced. My trailer is a 32' trail vision and the tongue weight is roughly 620lbs. It took less air in my helper bags to level the truck. For the 1500s, the front shocks are non-adjustable. Was a bit concerned about it, but am totally satisfied.
Anyhoo, just my opinion. Take care all.
:seeya:
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 1,130 Guests (See full list)
