Door/Window wiring
TireSmoker
Having a little problem...just finished putting speakers in my crew cab doors, and after hooking everything back up, I can't control the driver's side rear window. Did I plug the harnesses on the driver's door wrong? Or did I mess something up in the back door? Can anybody tell me what order the plugs go in the driver's door?
Thanks...
Defintely go re-check the wiring at the rear door ...
You may have plugged the connector back in but many of these connectors now employ a locking mechanicism that secures it. If you didn't put the little clip in place or swing the latch, you may not have enough contact. Or the connector simply fell out.
Re-trace all the wiring, verify everything is connected (window motor, switch, etc). Also, since you say "doors" ... go recheck all the wiring in the driver's door, that controls everything.
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 1,143 Guests (See full list)
