Truck will not start
My lights and radio come when I turn the key but no start. It's like the battery would be disconected (Its cleaned and tight). I can hear the fuel pump buzz when I turn the key. This is the 2nd time in 6-7 months this has happened. The first time it just started right up after a while but nothing now. I'm thinking starter solenoid (it is not clicking and volts are low) or ignition switch. Any Ideas? :mad:
Thanks, Cory
When this happened to me (same as you describe) it was the battery. Any shop or parts place can test it for you, try jumping it?
That was the same thing mine did when the battery went. try charging it and see if it starts.
Check the main power wire connection to your starter. Try tightening the nut. If the battery is good and that connection is good and it sill doesn't work, your starter is probably bad.
My lights and radio come when I turn the key but no start. It's like the battery would be disconected (Its cleaned and tight). I can hear the fuel pump buzz when I turn the key.  This is the 2nd time in 6-7 months this has happened. The first time it just started right up after a while but nothing now.  I'm thinking starter solenoid (it is not clicking and volts are low) or ignition switch. Any Ideas? :banghead:
Thanks, Cory
    Selfman
    Selfman
  • Who's Online   2 Members, 2 Anonymous, 518 Guests (See full list)
