1996 GMC Sierra 5.0L to 5.7L swap
Hello all,
I am looking to put a fresh motor in my 1996 GMC Sierra Z71. It currently has the 5.0L motor and the 5 spd. manual transmission. I was considering upgrading to a 5.7L motor for the additional power for towing. I was wondering if anyone else here has done a similar swap to the same vintage of truck, and what else needs to be changed to accomodate the larger displacement motor. I already have changed the exhaust to a 2 cat system, so I'm sure that can be used, but was wondering about the remainder of the electronics and bolt on's. Any input is greatly appretiated!
Thanks!
Hello all,
Thanks!
I'm an old GM guy, but i believe that the 96 SBC still share common blocks. The major difference, at least in gen 1 engines is bore and stroke. All other parts, heads, intakes, manifolds, etc are interchangable. I do not believe that the 305 ECM has the correct calibration for the 350, this should be a simple fix by installing a 350 ECM also check the injectors, see if they have the same #. All external connections, wiring, fuel, coolant, etc. should be the same
I guess you and I are alot alike Bill87, as this will be my first engine swap in a fuel injected vehicle. I agree on all the physical aspects as far as being the same, it was the electronics I had the most concerns about. When looking at aftermarket parts, it seems they share alot of components between the 5.0 and the 5.7. The ECM was one of my concerns, as was the intake/ fuel injection setup. I guess I'll do some more part #'s digging to find out what else the two motors have alike/disalike. Thanks for the reply!
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,253 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
