2003 DRL's - How to get to the Bulb?
How does one get at replacing the bulb in a 2003 Silverado's DRL's? From the front or inside the engine compartment? Specifically: How do you get to the bulbs? If from the front, how do you get the cover off? Thanks!
PS: also: what would the trade part number be for the standard white replacement bulbs?
I think you just pop the hood, remove the metal clip/bolt, remove wires and unscrew the bulb, pop in the new one and reinstall everything. Should be pretty easy!
Cr
remove the whole headlight let it rest on the radiator support and reach down and remove the socket(turning it while pressing on the lock deal) remove the bulb.
Steve
Btw might be some info in the owners manual :cheers:
Steve: Remove it how? From the front somehow removing the lens or from under the hood like Opsbear7 says?
"remove the whole headlight let it rest on the radiator support"
OK, here's how to do for the next person to search this forum. Lay down underneath the front bumper, half-turn unscrew the bulb socket, replace the bulb in the socket, half-turn screw the socket back from whence it came.
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 309 Guests (See full list)
