Brake Controller
I just put a brake controller for towing in my 98 K1500. Looked up to connect the brake switch wire and not only can I not get to it, I don't know wich wire to connect to. There is a lot of wires. I'm used to just 2.
Does anyone know the best way for this or should I just run a wire back to the tail lights?
Thanks
On my 98 K3500 there's an electrical panel under the dash to the left of the brake pedal. Bottom left of that panel there's a connection port for the TBC: power/ground/brake light. I think the brake light/switch wire was light brown, but not sure. Easy to test with a test light. Works great for me, your truck is probably the same.
  • 7 months later...
Your right. Thanks. I'm used to Fords with the 2 wire brake switch. This works out great, cause I hate cutting factory wires!
Can you tell me what kind of connector you used to connect the brake wire to the pin in the block? Thanks
I just used a spade terminal soldered on the end of the wire. It'll plug right in. You MAY be able to find a factory plug, but the spade terminal is easy and I have a bunch laying around. Good luck.
Thanks for the info. That is what I had in mind also, just was not sure it would work since the pin is so small.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,044 Guests (See full list)
