superchips error code 2
Can some one please help me it is 8 and they are closed. I pulled the program out and then wnet to put it back in and it gave me a error code 2 lost connection when tring to install program.
what year truck? LB7? LLY?
does the truck start and run?
I assume you pulled all the correct fuses when you programmed it right? Try disconnecting the batteries for 15 mintues...
I got it to working now. It only shows to pull one fuse and that is the onstar fuse. I do not know what the deal was but I just let the truck set for about 2 hours and wnet back out and tried it again and it worked just fine.
    btm
    btm
  • Who's Online   1 Member, 0 Anonymous, 1,146 Guests (See full list)
