Long Tube Headers
does anyone know where i can get a set of long tube headers for a 1998 GMC Sierra with a 5.7? do they really make more power or is the power in a different RPM range? any info will help.
You want 34 inch tubes that are no more than 1 5/8 inch in diameter. The longer tubes will enhance mid range power better than shorter tubes. If you want the best there is for the street, install a set of Thorley Tri-Y headers. They are expensive but will give you the best low and mid RPM power of any street header design out there.
thanks for the help man
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,105 Guests (See full list)
