ABS and Brake Light Go On-pls help
Notpil22
Please help, as I am leaving on a long trip on Thursday.
After driving my 01 Tahoe for a minute or two, both the amber anti-lock, and the red brake light come on at the same time.
They stay on the whole time until i turn the vehicle off.
When restarted, they stay off for a minute or so, and then come on again?
The dealer said it was some kind of ground bolt, and wanted $100.00 bucks to special order this bolt?
How can the ground be good when the vehicle is first started, and then get bad a minute or so later? I can duplicate this problem over and over.
This has been an ongoing problem for a couple of months, and I am going on a trip, and do NOT want to stare at those lights the whole time.
The anti-lock brakes work just fine, and I just installed ceramic pads and fresh rotors on all 4 wheels.
Someone here must know the answer.
Thanks in advance.
Would be nice to know what codes they turned up.
Doesn't work quite that way. Various performance tests are run by the ABS system all the time and even something that's a problem all the time may take a minute or even a lot more before the system sees a problem and turns a light on.
The only ground I can think of that's been quite a bit of a problem is right on the frame mount bracket. Look below the front edge of the drivers door at the frame. You can't miss the grounds screwed to the body mount bracket. Dunno if that's what they're talking about but it sure shouldn't take any $100 part if that's it.
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 501 Guests (See full list)
