How Much Oil Does Front Axle Hold?
How much oil does the front axle of the Tahoe 4wd hold? I am replacing the front and rear. I found a thread indicating a little over 2 quarts for the rear, but can't find info on the front. Cannot find it in the owner's manual either. Thanks in advance!
    bellssn690
    bellssn690
  • Who's Online   4 Members, 2 Anonymous, 831 Guests (See full list)
