Color INFRARED Reverse/Backup Camera
For Sale:
I used this on my 1999 Z71 for about 4 months before I traded the truck in. Before I purchased a backup camera, I looked at all of the units I could find, and this one was the best. It displays a perfectly clear color image during the day, but as night falls the infrared kicks in and it sends a clear black and white image to your monitor. In the middle of the night, with no ambient light, you can see at least 8-10 feet back clearly, and even more if there are trees, cars, or other objects for the IR to reflect off of.
I mounted this unit to the left of my trailer hitch underneath the rear bumper with a single screw. I will include the 65' cable that sends power to the camera and sends the video to your monitor.
The picture below is from RVCams.com. I can take images of the actually unit if needed. I will search my computer to see if I have any pictures of the unit installed. RVCams.com, where I purchased this camera, and the only source I've found for this particular unit, sells this unit for $175.
I'll sell mine for $125 shipped.
Oh yeah, the camera is waterproof too! You could submerge the camera and it would work fine, though I've never tried it. It's marketed to be used on RVs and on the rear of boat trailers that are submerged on ramps.
The camera also captures a reverse image so that it works just like your rearview mirror.
Complete Specs for CICVH Camera:
Camera Specs:
TV System
NTSC, PAL
Image Sensor
SHARP (brand) 1/3-inch Color CCD Image Sensor
CCD Effective Pixels
(NTSC)768(H) x 494(V)
SYNC System
Internal
Sensitivity
0 lux (IR ON) / 0.3 lux F2.0
Board Lens
4.3 mm / F2.0
Resolution
480 horizontal TV lines
Signal to Noise Ratio
better than 48dB
White Balance
Auto (2500-95000° K)
Electronic Shutter
(NTSC)1/60-1/100,000 sec.
Video Output
1.0 Vp-p composite video at 75 ohm
Gamma Correction
0.45
Gain Control
AGC (Automatic)
Water Resistance
IP67
Operation Temperature
14°F to 122°F
IR LED
12unit, 850nM LED
View Angle
70°
IR Distance
10 meters (~30 feet)
Power Supply
DC 12V 280mA
Construction
Aluminum, with stanless steel fasteners
Dimensions
2.2" (w) x 2.56” (d)
  • 5 years later...
I am interested but know nothing about hooking one up. Do you have instructions detailing the hook-up.
Thanks,
Karl
    Patrick Fergy
    Patrick Fergy
  • Who's Online   3 Members, 0 Anonymous, 1,013 Guests (See full list)
