Took my truck to the track
I took my truck (2005 gmc sierra 5.3L aluminum block) to the track the other day to watch a friend race.. just for kicks I ran my truck down the quarter for the "grudge runs" (i.e. high school kids with ricers) and ran a 16.30 at 86 mph... Only mod I have done to my truck is put a borla cat back exhaust... just wondering what the normal stock time for a truck like mine was???
yup, sounds about right...nice run! With a little launching practice and some cool temps you could probably flirt with low 16's or high 15's. How far above sea level are you and what were the weather conditions?
with 3.73s high 15 would be about right and with the 4.10s you would be mid 15s to tell you the truth a 3.42 to a 3.73 gear swap will get you 4 tenths lower and to a 4.10 you reach a 7 tenths lower.
To be honest i watched my buddy with a 5.3 reg cab short bed pull :15:03 in the quarter.......all he had was a cat back flowmaster.
i belive that a 4.8 stick shift rcsb will do the same
agin that out of hole time is a killer
15.03 sec. 1/4 mile on an all-stock 5.3 motor w/ only just a cat-back? Not doubting the time, but I think there's gotta be a little bit more going on in that truck than just a cat-back IMHO.
dead honest dude the truck had only cat back exaust and a suspension drop 5-7 to be exact and on top of that running on some "20 inch wheels. Unless capitol raceway had a electronic problem at the time....lol
i think that is fair. here's my story. i have a 5.3 h.o. and my best run was 15.1 when i had KN 77 series intake kit, street performance tb spacer, true dual exhuast with 2 two chamber flowmasters and a diablo sport tuner and i kept messing with the shift points and the torque manangement system.
now i have a comp cam with springs and have a dynatech supermaxx header system coming on the way this week. but after i got the cam and springs...i went to the track and this is what pissed me off. i got a 16.0 every time. I am hoping and hoping that i need a tune to fix this crap cuz i still haven't got my pcm tuned for the cam and boy does it lope like crazy!
I suppose you're gonna tell me that your buddy was running a 3.40-something rear as well when he pulled that 15.03? If so, then I seriously think something's not being mentioned... :D
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 545 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
