How to switch the factory installed XM to Sirius
I have been a Sirius subscriber since Jan of this year. Last week i purchased a '06 Silverado that has the 3 months of XM in it. I'm trying XM out and if i didn't like it i was going to give my Sirius receiver to my sister. So far though, i'm thinking about just keeping my Sirius but adding another radio to it allowing my XM to expire. Does anyone know if i could remove the XM unit and just replace it with the Sirius one...keeping the antenna from the XM to use for Sirius? And where i can buy a sirius unit? I miss Octane 20 w/ kayla and my comedy stations from Sirius....i'm not really satisifed with the range of music Squizz has. Too much of a variety for me, which was the reason why i bought satellite radio in the first place.
:cheers: Foot :eek:
All you need to get is the SIR-GM1 tuner. It is a simple switch that allows you to keep your factory radio and antenna. It takes 5 min and works like a charm
Do you need to have XM radio already installed for this ? Do you know if you can use the factory XM antenna or do you need another antenna ? Can you elaborate on this setup please...thanks !!
yes you can use the factory XM antenna, all you have to do is remove the yellow clip that holds the antenna into the xm reciever. Your radio has to have a Band button to be compatible with Sirius
Thanks alot! I'm going to try that.
Where do I get one of these? That will happen in my truck next year when nascar goes to Sirius
these were scheduled for release in the spring and for some reason were delayed. they've just now started to show up in the marketplace
as Directed Electronics gets more pumped out - you should be able to find them anywhere
I was noticing that they were a little pricey. One of my podnahs has a Sirius Connect unit in his truck and he told me he only paid $50 for it. I'll probably just hold off until the last month of my XM trial before i switch back to Sirius. hopefully by then, more companies will have them and it won't be as much.
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 501 Guests (See full list)
