Rear end fluid
EDT
I panicked after having new vehicle serviced 2 times and never had any fittings greased then checked rear end and could not touch. panicked and took to different dealer and was told you need a special tool to check and level was fine
Truck is 2006 2500 HD 8.1 Allison 6 speed with standard 4.11 rear
I cannot speak for your particular truck, but on mine I do use a very special tool. A piece of mechanics wire about 10 inches long with the first 2 inches bent at a 90 degree angle. I stick the bent end in the hole of the rear end and make sure the grease is within 1/2 of an inch of the bottom of the hole.
Very expesive and special tool. Unless your rear end is very different, someone was pulling your leg.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,225 Guests (See full list)
